[FS: General] SmallHD DP1 9” 720P HD Monitor Bundle
betonme
Condition: Maximum 3 hours of use (indoor) / No scratches
Retail Price (new) SmallHD Bundle: $989
Package Includes:
SmallHD DP1 8.9” 1280x768 18-bit Monitor
2x SmallHD Low-Profile Batteries
1x Battery Bracket
2x Battery Chargers
1x Quick Connect 4-Sided Sun Hood
1x Padded Neoprene Sleeve
All original cables and accessories are included, as well as Quick Start Guide and original SmallHD Monitor box.
General
  • Dimensions: 8.99 in. x 5.80 in. x 1.22 in.
  • Weight: 1.66 lbs.
  • Construction: Single-Piece CNC Milled Aluminum Chassis
  • Mounting Thread Type: 1/4–20
  • Mounting Points: 6 Total
  • Operating Voltage: 12v (regulated)
  • Power Consumption: <12W
  • Operating Temperature: 0° — 60° C / 32° — 160° F
Display
  • Display Type: TFT-LCD
  • Diagonal: 8.9 inches / 226mm
  • Resolution: 1280x768 (WXGA)
  • Contrast Ratio: 500:1
  • Native Aspect Ratio: 15:9
  • Brightness: 300nits
  • Viewing Angle: 178° H/V
  • Color Reproduction: 18 Bit RGB / 262,144 colors
  • LCD Finish: Glare and Polarization Filters (Low Gloss)
  • Active Viewing Area: 7.635 in. x 4.581 in.
  • Pixel Pitch (pixel size): 0.005965 in. / 0.1515 mm
  • Pixels Per Inch (ppi): 168
  • Backlight: LED
  • Response Time: 28 ms
Connection Types (Inputs)
  • 1 x HDMI (Type A) Female
  • 1 x Component (3 x RCA Female)
  • 1 x VGA 15-pin D-Sub Female
  • 1 x S-Video 4-pin mini-DIN Female
  • 1 x Composite/CVBS (1 x RCA Female)
  • 1 x Power (5.5mm OD / 2.1mm ID Female Barrel)
Signal Types
  • HDMI 1.3: 1080p, 1080i, 720p, 576p, 480p
  • Component: 1080p, 1080i, 720p, 576p, 576i, 480p, 480i
  • VGA (max resolution): 1920 x 1080 / 60Hz
  • S-Video: NTSC, PAL, SECAM
  • Composite/CVBS: NTSC, PAL, SECAM
  • Supported SD Formats:
    • NTSC — M, J, 4.43
    • PAL — B, D, G, H, M, N, Nc, I
    • SECAM
Make Your bid
If you have any questions, feel free to ask.
