I have this one myself. The height adjustment on this baseplate is good because you can access the battery without removing the camera from the baseplate.
Do you know if that baseplate system will work with the battery grip?
Hadn't considered the battery factor.
What length "Vertical Posts" did you get?
And which model GH are you using?
Thanks,
Bern
I have a GH2 and recently a GH3. I have 2.5" posts. I think the 2" would be not quite tall enough for the door to fully open. The height might be needed too if you use a lens that needs a support (eg Oly 35-100 with the Zacutto support).
