"High bright 450cd 7 inch integrated touchscreen 1920x1080*3 monitor."
Interesting
I'd be interested to know what makes this product more than just a custom computer built from off-the-shelf components. It looks a bit like a $500 mini-itx computer with a $150 LCD attached and maybe an extra $300 worth of graphics card and video i/o cards.
Hi,
Do you know what are inside the ninja or inside the cinedeck ?
They are computer based recorders, and the cinedeck is based on W7.
Regarding SFV, will employ last tech., high performance, including latest intel components.
This means internally are professional components, not consumer htpc or other ones.
The current case is a prototype, production will be a litle bit small and aluminium based.
LCD have resolutions up to 1080P ranging from native res. (up to 1080p is indicated in the bottom of the website). Native is 800x480 as other ones, but at 450cm/2 hight brightness i can tell you that's not a cheap panel.
Did you know about uncoming -until summer or later- new LaCie thunderbolt 700MB/s drive ?
SFV will embedd the same harddrive/s that are on that LCIe 700MB/s model.
The SFV will bring more performace transfer rate than LCIE. Around 900MB/s.
Do you think a labtop or a sub 2k mini computer is able to manage uncompressed hd. video well.
Our experience indicate that not, for professional video you can't.
From what I understand the cinedeck is similar to what you are proposing but it clearly uses a custom chassis and some custom components, and I think it uses CineDDR software which is $3k alone.
I though uncompressed HD recording/playback was primarily limited by storage bandwidth, and with modern SSDs, it seems like even very low-powered computers ought to be able to manage uncompressed HD. Compressed video is tougher since it require more CPU speed which requires more power and more cooling.
I used Nanoflash on a few occasions and I must say the technical support from CD is just amazing.
If you would not need to call the technical support at all - now THAT would be amazing. :evil:
Frank
