Selling a 6-axis robotic arm. It can be used for small commodity shooting to make special visual effects. The arm`s working area is about 80 cm and a load of 4 kg. Basically, there are small machines such as sony A7, bmpcc ,Z cam, s1H, Komodo...There is no problem with follow focus motor.
The weight of the body is only 12 kg, it is convenient and easy to carry. The arm can be operated by a single person,it can be setup in 15 min. The black coat was customized. The tool side was added quick-released plate so that it can attach camera easily, also come with a L plate that can mount camera in 90 degree. The base of the arm is also custom-made, you just need to prepare a 150mm bowl heavy tripod to work with.
It has been used for about half a year. The appearance and body are very new, and function is normal. The only drawback is that the arm itself is not strong and fast enough, and there is a small vibration that can be compensated later or change some waypoint / speed setting.
The sale includes personal online teaching. Even if you don’t use it before, I can also show you step by step to operate and some share some tips.
asking for $5300
here is some demo:
please contact to:
allstar.cine@gmail.com
Tom
