Slow motion?
booji_boy
How does slow motion work with the DVX? I've looked through alot of past posts, and haven't seen anything on the topic. Can smooth slow motion be achieved? What's the Dvx's highest frame rate?
-Rob
Re: Slow motion?
You'll have to do this in post. You can't do slow motion "in camera". Unless you are talking about time lapse?
Try looking in the thread for your specific editing system. This thread is for posting clips and screen grabs.
;D CAVEMAN
Re: Slow motion?
This should be in the technical section...
But, in NTSC, the DVX can record either 24P, 30P, or 60i. You can get good slow motion from converting 60i to 60P (through de-interlacing however, losinghalf your resolution) but then you can slow it down to 24P, and have the effect of having shot in 60 frames per second.
You can also shoot in 30P and slow it down for a subtle slow motion effect, and it would be "perfect" because it's still progressive.
Re: Slow motion?
I have heard of a program called "Boris Continuum". It is supposed to take your video and make it smooth slow motion without you having to capture it a specific way. I have never used it, but has anyone used it? I would like to see a sample of how well this works.
Re: Slow motion?
they have a demo for the program... i am going to test it out right now. I will post the sample when I am done with it
Re: Slow motion?
I have found that in FCP HD I can slow it down with the speed adjustment. (ctrl + J ) I usually don't go any slower than 55%. If I do I use a shot with no fast movement. Also setting your shutter speed to something a little high, like 1/150 will help a great deal. When I do want to go lower than 55%, I add the motion blur effect from Joe's Filters. I then tweak it to a low enough setting to lose the choppiness but retain as much sharpness in the picture as possible. This works pretty good. Lots of trial and error to figure this out. Hope it helps.
Re: Slow motion?
Hey the 100E should have the 30P just cause of that, or 33P would have been way cool! True subtle slow is not that far off it seams :-[
