Could you explain this a bit for me please?Peter Gaudry said:After going through a lot of this, I will tell you that 30p is not that noticeable. You're better going for 60i if you want it to look slow.
galt said:Okay I am confused.
Lets say something moves 30 inches in one second.
If I record it at 30p, each frame shows 1 inch of the movement.
If I record it at 60i, each frame shows 1/2 inch of the movement, but it is interlaced. So I end up with 60 half-images. When I re-interlace prior to conversion to 24p, I would only have 30 full images again, each one showing a (interlace blurred) 1 inch of the movement.
I don't see why they would yield different speeds at 24p, unless you were converting 60i to 24i...
Did I express that well enough?
coffee said:I assume you don't have Barry's book nor the DVD. I highly recommend it. :thumbsup:
I'll try my hand at this but I'll use 40 inches as my example.
40 inches per second in movement
40 inches shot in 30p then slowed down = 50 inches in final result slow motion
40 inches shot in 60i then slowed down = about 75 inches in final result slow motion
This is my understanding, soon to be tested.
