FS7: slog3/Zebra
CJ Ricottone
While mlut is turned on in my vf, are the zebras based off of the slog or the lut values? I'm assuming they are based off of the lut reading, but I'm just a bit confused since the waveform won't turn on while I'm recording log and monitoring 709 in my vf.
That´s correct, with mlut the zebra is based on the lut reading.
Pro Tip: Use Ben's LUTCalc to determine where to set your Zebras if you are monitoring with or burning in home-brewed LUTs then make an ALL Files preset for each setup.
