Lenilenapi
Carbonite Member
I am about to get my F3 back with SLog installed and am wondering about the color pre-sets. Is it still true in the most recent software that you can only choose Tungstun or Daylight and are locked out of all in between color temps as well as green/magenta adjustments?
If so - I am a bit confused as to why. I understand that in theory Slog would use all the available lattitude of the chip and so there would be nothing to gain by trying to adjust the base color . However in that case why is there a choice for tungstun or daylight. Emulating film is no reason to l;imit choices on an electronic camera.
Presumably the base chip is daylight sensitive so wouldn't a Tungstun choice reduce lattitude and or raise noise? This was true for the RED and so many people would filter it blue to retain all the lattitude.
As I recall isn't it now possible to color balance the Alexa in its version of SLog.
My concern is less with the final image actually than with the monitoring image (for client) and the back-up SxS recording. Any way to color correct those when shooting sLog?
Is there an advantage to shooting the F3 blue?
Lenny Levy
Lenny Levy
