I am sorry I did not take the time myself to figure this out, but it seems very simple and possible.
Using CVP editor is it possible to make a SLOG 2 or 3 setting for the F35? I saw Jo Kami was able to make a Pana-log curve using CVP editor.
I do not think the SLOG 1 is inferior, however I do think it would help colorist a lot if given F35 footage they could handle the same as footage from FS7 or F5.
Is it simply a matter of setting the curves to the right levels or is there a reason that even with the same curve applied, the F35 is not going to work with SLOG 2 and 3 Luts?
If you don't have one, you need a cheap memory stick duo and reader to load files onto your F35.
