Slider for your FS700.
PremiumIC
It seems like most of the sliders out there are meant to support DSLRs. Anyone try their FS700 on sliders? Really looking to buy one in the next few days but no one has really reviewed using a heavier camera on these products. I'd hate to spend the money and have it immediately be worthless.
I used my DSLR slider with no problems!
But it was pretty shitty, so I just ordered the Kessler Stealth Slider with a motor drive.
My old slider was the GlideTrack Hybrid.
I use cineslider from Kessler with motion control. I'd say it's the best one I used out of all. Really strong, build with precision, superb! I'd say even more, all Kessler gear is amazing.
I still use my DSLR slider which was the DIY ZaZa Igus slider. Works the same and works very well with the FS700. The FS700 isn't really that much heavier than the 5D. With battery, the 5D body is about 2.3 lbs, the FS700 body is about 2 lbs heavier with battery so not that much of a difference.
I guess in the end it's a lot about support, I think I'll probably go for the DJ since Frank likes it. I feel like I've probably read and used a ton of his advice over the years while lurking on the forums. Thanks by the way. It seems like you can do a lot with it, and the price point seems about right for where I am in my career. But it's good to know the others out there work find. It's really tough to find any information about if it REALLY works with a camera. Sure it might hold 200lbs, but that doesn't mean you can slide that with silky motion.
I'll play my old tape.
Sliders you should consider if the slider is for a bare camera, or a built camera, do you have time to unbuild the camera, can you pull focus without a monitor on a moving shot?
You should consider if sliders are limiting when used without a second head because you cant rotate a subject and the subject can look like they are sitting on a conveyor belt?
If you conclude that you need both a slider for a built camera and a second head then the device will be so massive as to surely require a second tripod..
Which means using floor track/dolly for your sticks is a more nimble way of operating
And considering floor track, moving the whole rig including sticks, has more intertia, and a lower centre of mass the shot quality tends to be far higher.
Floor track is of course difficuly on a ploughed field, if this is part of your spec, I would go back to thinking a slider
These look like a clever bunch. http://www.longvalleyequip.com/dolly.php
S
I put mine on a 1m Konova K5 with no trouble. It was a fairly small rig: just a Canon zoom (35-70mm as I recall), but had a fairly hefty head on the slider (Sorry I don't know the details, the head and lens weren't mine!). In fact the slider performed beautifully - I think the 'max weight' is something like 30kg, but I'm not sure. I must admit I think it is a great bit of kit for $1000 (so, given that it cost $429, I had to say I love the damn thing!)
It has it's issues of course: it's a tad noisy (sounds like you're sweeping the floor when sliding!) but other than that I think it's great. I also bought the dedicated 'hand crank' kit to make me feel like I'm using a 'Phillip Bloom' pocket dolly (and because I like slow, steady slides).
If you're looking for a budget, but good slider, I can recommend it. If you want something a bit more serious, get something else.
I use the Phillip Bloom Pocket Dolly from Kessler with our FS700, it works great and can even hold it when it's fairly kitted out.
Well rats, I spent a lot of time researching this topic to no avail and it turns out all I had to do was ask. I ended up ordering the DJ slider. It was on sale and had decent reviews, will report back when it arrives.
But it was pretty s*%tty, so I just ordered the Kessler Stealth Slider with a motor drive.
why was it s*%tty with the glidetrack?
My fs700 is on the way and i have the GlideTrack Hybrid and would like to know what you didn't like. For my 5d2 with any lans I put on (even 70-200) it works superb (but i do have it motorized..)
I've used mine on my Konova K5 slider, worked well. I have yet to use my Konova motors, though. Only weak spot is I have a modified ball head (attached a Manfrotto 577 QR plate), I need a find a better way to fasten the QR base to the ball head.
I'm sure a wider track/carriage would help it feel more stable, but I didn't have an issue with it on the Konova.
It could hold the FS700 just fine, it's just the way it's built I don't like!
It picks up so much dirt and even though i'm very careful with dusting it of before use. It takes nothing to make the wheel bearings dirty. And the dirt and dust really sticks in behind the bearing. The way to tighten it to the rails also destroyed quite a few of the yellowish plastic things that held it in place, so I had to replace those a few times.
I guess the design just wasen't for me. I travel a lot, and often use different grips and assistants that isen't that careful with my gear that I would wish for!
Bought the cineslider instead of the Stealth, and really look forward to compare the two!
I used the FS700 on Kessler cineslider (5 feet version) both with, and without the motors. Using it without motors is more convenient for slowmotion work. Less stuff to lugg around and faster to setup. You can control the movement speed better, simply use your hands wrapped around the fluid head. Oh, we also have the high hat riser for fluid heads. When it comes to live video, it's the other way around - using a motor produces smoother overall result. Also, keep in mind that if you want to use motors for slowmotion, you will most likely need one of their fast motors (500:1 or even 1000:1). We have the 500:1 and it works much better then their standard timelapse motors. Those are just too slow, and when you load the fluid head, the camera and mattebox, they become even slower.
We have the cineslider for about 2 years, and it's starting to show some signs of wear. The dolly travel is not as smooth as it was, there are some strange bumps, slowdowns etc. on certain parts of the track. It's definitively time for a service visit. Only problem is - we're in Europe and Kessler is USA. I'm still too scared to check for shipping costs, but I got a feeling it will not be cheap.
I have the Bloom Kessler Dolly. I liked it a lot with small cameras like the gh2 or the 5dmk3, but now with the 700 I am struggling. I do food/tabletop stuff, my sets are prety small, lens distance is about 70cm, so precision is really important. Unfortunately this slider is not stable enough, it laterally twists and wiggles, rigging it solidly is very difficult. after weeks of trying I decided to give a P+S Technik skater dolly a try, the original inventors of the whole skater hype. all my tries with cheap imitations (Konowa and other crap) had failed, so I havent thought much about them, but this one is fantastic. finding the right surface can be a bit tricky, but it is so much more stable and doing curved moves really allow for new moves. it's expensive, but as often, worth its cost. I went for the cheaper junior one, as it is 1/4 of the cost to the mini and it still carries up to 11 kg.
Been using the PB Pocket Dolly as well for our shoots:
