Slider for AF100
Mike Harvey
Anyone have any recommendations for a good slider? I'm probably going to pick one up in the next month or so for a couple of projects.
Thanks!
A few things you could look at:
Dry type sliders are well liked for their price, and handle just about any weight
http://www.amazon.com/dp/B005O24IRK/?tag=viewnow-20
But roller bearing sliders are a better level of smooth, and now it seems have come down in price quite a bit:
http://www.amazon.com/dp/B0097ERSQY/?tag=viewnow-20
longer version
http://www.amazon.com/dp/B0097BCBM8/?tag=viewnow-20
I have not tested any of these, i own a DIY and a konova. but ^^ are basically the two types of sliders that exist in the affordable world, a bigger jump would be the kessler and cinevate sliders at $500-$1500 beans
Recently bought a Kessler Pocket Dolly, it's been very solid, smooth, and easy to use. I bought it because it's easily upgradeable with motor drives once I need that capability.
I like the concept of the Cinevate Pegasus system, it seems most flexible but requires more support equipment than I typically have time or budget to haul around.
Are you using this on a 100mm or 75mm ball head tripod? I was looking at their website, and I got the impression that if mounting on a 75mm head (which I have), you would need additional support.
I bought the 2', and it works fine even on a lightweight Manfrotto 755xb legs. I've used and rented the 3' version on 75mm ball tripods without issue.
Thanks!
How portable do you need to be? I have a homemade Igus slider for hiking. For commercial production I use the Kessler Cine Slider 3 foot. I would like to replace my light weight home job soon but it works pretty well if the camera is light.
Reasonably portable, and for commercial shoots... something along the lines of the Kessler pocket dolly 2' that Mcbob was talking about.
I have two concerns with light weight sliders. With a fully loaded AF100 rig and long lens is it stable enough? and they limit you to a very short camera move. Have you considered a skateboard dolly. You can't beat the versatility and adaptablity. I built one about 15 yrs ago and have recently built a few for other shooters. You can choose the length of rail that fits your need. There are a number of folks selling them including myself. Here's my simple design.
https://vimeo.com/hankgifford
I have Kessler's 2' PB Pocket Dolly, & 3' CineSlider.
My 75mm Satchler CF SpeedLock sticks can just barely support the shorter slider when topped with a 10 lb camera, & 5 lb head.
The CineSlider is much beefier so goes on 100mm sticks, & quick releases are used to attach monopods to both ends for added support.
With either setup I use a Manfrotto half bowl adapter below the slider, & a ball relocater, or short Hi Hat, for the fluid head above. Sometimes I'll just flatmount a Manfrotto 701HDV or 502HD head instead, but whenever practical prefer a better fluid head in a bowl.
The 2' is much easier to employ/transport, & generally lives next to the Satchler in a tube case, while the 3' flys in a dedicated Pelican Storm rifle case, which always gets scrutinized by the TSA.
Typically my editors won't dwell more than a few seconds on a slider shot, so the 2' gets used much more often than the 3', & I often just go handheld with a bit of slomo for similar, or more complex moves, especially when filming B-Roll.
The Kessler CineSlider is fantastic. I use it with my fully rigged AF100 and my F3.
We have an MYT Works 4' medium Glider, which has a detachable mount that can work as a hi-hat or be placed on a skater dolly. It really has a great feel, light weight and very strong, beautiful machining work. Has 5/8" receivers on the bottom to use light stands and 3/8" and 1/4-20" threads all over the place.
The medium and large capacity sliders are 100mm or 150mm option for the latter, the small is 75mm. They'll do any length required. http://www.mytworks.com
Hi Guys
I've just bought a Konovo slider and have got some great test shots just bolting the AF101 to it but I was wondering what the best tripod head would be to go between the slider and the camera. I've tried the a fluid head from a Manfrotto monopod and the shots look great but I can't pan as there's no panning mechanism on the head.
Any ideas would be greatly appreciated.
Regards
T
