Single Sequence, Multiple Files on Export
awelgraven
I have a sequence in Final Cut. It has about 50 markers in it. Is there any way to export it so that each Marker is a seperate file? So in this instance, I'd end up with 50 unique QT movies...
I have access to compressor as well... if that helps.
Thanks for any help...
I know you can cut all of those parts into sequences and batch export the list of sequences, but I'm not sure about what you're asking. I'd be interested to know if it's possible as well.
Yes, me, too. Pretty sure it can't be done. But, hawk, how do you do the batch export of sequences? Can you adjust export settings for each?
I'd have made each of those segments a separate Sequence. Not a simple way to do this.
Send To Compressor, set In/Out points for first section.
You can duplicate that job, reset In/Out points.
Repeat as needed.
Submit.
