galbach
Perfect condition used 1 time... Sold
The ENG-44 mixer has more important features than any other ENG audio mixer in its price class, and offers superb sound mixing quality, backed by our guaranteed ENG mixer specs. The ENG44 portable audio mixer is also compact, rugged, light weight, reliable and easy to use-- strap it over your shoulder or use it table top for complete hands on sound control-- on location or anywhere else. The ideal ENG mixer for video production.
ENG-44 Audio Mixer Features
Four mic/line XLR audio inputs
Expandable- Gang two or more ENG-44 mixers together for 8, 12 or more mic/line inputs
Each mic/line input serviced by its own:
Gain control pot (volume control)
Switchable 48 volt phantom power
Switchable low frequency roll off filter (low cut filter)
Pan switch (left-center-right)
Mic/line level switch
Master Gain control
Compressor/limiter with indicator light
Mix buss input via 1/8" jack
Front panel slate mic with momentary push button for fail safe press-and-release voice slating
Reference tone (1KHz tone oscillator)
Switchable tape return input (for monitoring to confirm that audio is actually being recorded to tape)
Tape return level adjust
Balanced left and right channel XLR outputs
Auxiliary 1/8" unbalanced mic level stereo output jack
Mixer main headphone output on 1/8" jack with volume control
Boom mic operator headphone out on XLR jack
(This eliminates need to carry a spare cable with 1/4" plugs. Rely on the spare xlr cable you're already carrying and carry a spare 1/4" to xlr adapter)
Power on/off switch
Automatic battery/external power switching
Battery and external power LED indicator lights
Battery indicator flashes when battery life falls below 20%
Slide out battery compartment for quick and easy battery changes
Extended battery life-- 14 hours of normal mixer operation conditions
External power jack for use with AC adapter
Mixer fully protected against battery or external input reverse voltage
AC adapter included
Rugged aluminum shoulder strap ears and attachable/adjustable shoulder strap
Left and right channel LED audio VU meters
Brightness switch for audio VU meters- switch to High for viewing in direct sunlight
Left and right channel balanced XLR audio outputs
Rugged anodized aluminum chassis
Made in USA
Master Gain control
Power on/off switch
AC adapter included
Made in USA
