Simultaneous S-Log +SDI + HDMI?
Nate Weaver
Hi,
My camera just went out on a rental, and they need HDMI for EVF, S-Log, and 59.94 SDI output via the monitoring SDI tap.
Normally this isn't something you can do when S-Log is enabled via the output menu (the "old" s-log enable menu)
If you enable s-log via Picture Profile, (and turn off s-log 1.5G mode) do these output constraints go away?
Does anybody feel like checking this for me since my body is not in my hands?
What is the record codec? 59.94 interlace or progressive.
I'm pretty sure if HDMI is enabled then SDI monitor out is off and SDI will be whatever you are recording.
Get an HDMI to SDI adapter if you need that and loop through the EVF
S-Log should have nothing to do with it.
It always has.
Recording 23.98
In non-S-Log, you have the menu option of having both SDI+HDMI outputs active. This was enabled in somewhere around v1.3
In "traditional" S-Log, you can only get one or the other, either monitor output SDI or HDMI, but not both. Can't use the 23.98 loop out of the Samurai because 1-It doesn't have a viewing LUT, and 2-it's 23.98. We need a 59.94 interlaced signal to video village.
Aware of the external box solution, my question is if anybody has tried Monitor SDI+HDMI simultaneous using Picture Profile S-Log.
SDI monitor out will not work when HDMI is turned on. SLOG or PP. Only one or the other can access output. The SDI A will be active, but if you need LUTs they will be in the VF. Not on the A output.
And if 1.5 is off it is still one or the other.
They need a SDI to HDMI converter or an SDI VF.
