Simultaneous output of SDI & HDMI question
roro20
I know I remember reading about there being some limitation with this, and I cant remember what that was.
What I am wondering is if I can run 2 monitors at the same time- 1 via HDMI and 1 via SDI. One of the monitors ONLY has HDMI. I dont have the SDI monitor, so I cant test this.
Thanks.
From the FAQ's:
6. Can I have the viewfinder and LCD on at the same time? Maybe. Depends on your combination of settings. First, go turn EVF MODE from AUTO to ON. That will let the EVF (Electronic ViewFinder) stay active when the LCD panel is open. Second, look at your SDI output setting -- you cannot have EVF, and LCD, and SDI all at the same time. You can only have two of the three. That's why the SDI OUTPUT menu item even exists at all, is to turn the SDI off when you're using the other outputs. With SDI OUT set to ON, you can have the LCD and the HDMI, or you can have the EVF and the HDMI, but you can't have the LCD, EVF, and SDI all at once. It just can't do it. You have to pick. Note, HDMI is always active and outputting, UNLESS SDI 24PsF is set to ON. That will disable the HDMI output.
So, yes, you can definitely use both monitors. You just will have to choose whether you want to use the AF100's LCD or its EVF, as you couldn't have all four outputs simultaneously.
