Sightly Crazy, Slightly Serious - iPhone and mixer combo and iphone/wired lav combo
It is possible, yes. Now, whether it's a good idea...
I have recorded to iPhone and iPad in the field (VO) using the USB out of a MixPre-D and lightning>USB dongle. There are some decent, free recording apps out there like RØDE Rec and Voice Record Pro.
There are also some small, battery-operated interfaces with Lightning connection (like THIS). These are fine, again, for something more controlled like VO as they leave the iOS device's headphone out free for monitoring.
As for the wired lav/iPhone combo for actors... I'm not a fan of planting a lav and small recorder on someone, hitting record, and hoping nothing goes wrong. Seems just as iffy, if not moreso, with a phone. There's just too much that can go wrong, and no way to know until after the take. The RØDE SmartLav+ does a decent job, and I've used it in a pinch with Filmic Pro, but it takes up the iPhones 1/8" port so there's no monitoring. There is a splitter that supposedly conmects headphones at the same time, but it has varying degrees of success and most of the reviews look terrible.
The recorder you linked is a terrible idea. Digital voice recorders are generally optimized for MP3. They're memo recorders (like microcassette), so they're intended for recording as much information as possible in as little storage as possible. Great for taking notes, not so much for dialog-for-video. While this one does say it supports WAV format recording, it doesn't say what the maximum resolution is. I also wonder if the VOR feature is defeatable. I'd also be wary of the overall sound quality, expecting noisy pre-amps and not much manual control over recording levels along with useless record level metering.
Is it possible to use a mixer and dump a single channel into an iPhone?
Just wondering what sort of plug I would need to feed the iPhone.
News reporters do this all the time. They have specialty gadgets that simply use the mic input on the TRRS plug. There are probably even next-generation gadgets that use BlueTooth.
Also, has anyone done a wired lav and iphone for recording actors if you don't have wireless lavs?
Sure. Rode make a version of their lav mic that plugs directly into an iPhone TRRS plug. They even include a software app to go with it.
And another company (who I don't recall at the moment) make an app that is a remote-controlled recorder.
You (the sound mixer) use your iPhone to control (start-stop, adjust record level, watch level indicator) the recording app on the subject's iPhone.
The quality would almost certainly be limited by the mic preamp in the recorder.
