Shutter speeds?
Azmyth
What shutter speeds are you guys shooting films with?
60? or 50?
My HV40 has a setting for 48. I would assume 50 is the closest to that, but I also read somewhere that this is bad if your using flourescent lights?
If you're in the US and shooting 24p then 1/48 is the norm. Basically 1/48 is equivalent to a 180 degree shutter angle which is typical when shooting film. 1/60 would be for when shooting 30p and 50 for 25p (PAL users). If you were shooting computer screens or under fluorescent lights then you'd use 1/50 or 1/60 depending on your power Hz rating to remove flicker.
The often given example for different shutter speeds is saving private ryan and the effect of seeing debris flying when there are explosions. This is the result of a faster shutter speed bringing fast moving objects into sharp focus. Slower shutter speeds will introduce blur.
