vitaluminosa
[deleted by user]
vitaluminosa said:Stacatto visuals? What do you mean by that?
I've explored the forums a bit further... is it wise to set the shutter speed fast, like you said, perhaps at 1/250 or 1/500, and then slow it down in post?
Thanks,
Danny
Kevin Briggs said:Hey Khmuse,
In film cameras is the shutter an actual moving part? Does it actually open and close 48/60/120/250 etc... times per second? Also what does the angle have to do with it? Does the angle of the shutter dirrectly relate to the shutter speed? What is the shutter made out of...does it matter?
Just curious.
-Kevin
Oedipax said:Remember that shutter speed isn't equivalent to frames-per-second. So shooting at a shutter speed of 1/500 will cut down a great deal on the amount of light entering the camera, and will give movement a very rapid, jerky movement (the popular example is the opening of Saving Private Ryan), but it's not like you're shooting more frames than usual. The best you can do on the DVX for instance is to shoot 60i (which gets you 60 motion samples a second, albeit at half-resolution) and then slow it down in your editor as per Barry Green's book. At 60i you would want to shoot with a shutter speed of 1/120 for the cleanest possible slow motion.
FWIW, I hated that effect.................... didn't look at all like the original battlefield film I've seen.
Barry_Green said:No post processing, they were done using a very abbreviated shutter angle (45 degrees I think?)
Barry_Green said:Well, the narrower the shutter angle, the shorter the exposure time. The shorter the exposure time, the "crisper" the image -- less motion blur. Also, the shorter the exposure time, the longer the shutter is closed, which means that the subject can move farther without being imaged between shutter openings. The effect ends up being not unlike a strobelight.
