From my limited knowledge of working with DV/HD cams, 1/60 is considered a normal speed. I needed more light in my image so I adjusted down to 1/15. From what I understand, this keeps the shutter open longer, so images are more prone to blur if they are moving. Are there any other issues with adjusting the shutter to this speed? If it is simply an issue of needing more light would you adjust to this speed? OR would you do everything you could to improve the lighting before adjusting the shutter?
Thanks.
Thanks.
