shutter speed options for 1080p/720p 24p/60p shooting modes??
iFilm7
Camera: EOS-7D
so
1080p/24p with shutter options: ???
720p/60p with shutter options: ???
i would like to know the varying shutter speeds i can use, i would use higher shutter speeds because i like the look, 24p at maybe 1/120 shutter? can it go higher?
for example: HMC150 shutter speed options are [1080p: 1/15 - 1/1000, whereas 720p: 1:15 - 1/2000]
Buut yeah, Wwhaat are the varying shutter speeds for
thanks!
Camera: EOS-7D
so
thanks!
The higher your shutter speed the sharper your image will be freezing the action and reducing motion blur. In film with a 180 degree rotation shutter the exposure shutter speed will be half the frames per second. (24fps - 1/48 sec exposure / 60fps - 1/120 exposure etc.) Quicker exposures with less motion blur will look less smooth.
The best thing you can do is run some tests shooting the same scene (Someone running is a good test) at each shutter speed from slowest to fastest and have a look at the results side by side. This way you will see first hand how it works and decide based on your own results, what achieves the best look for what you are after.
Haha thanks but what I was asking was what are the shutter speeds available? on 720p:
and on 1080p:
thanks again xP
bump
you know in HMC150 the shutter speed can go up to 1/2000 but only in 720p, whereas in 1080p it is limited to only going up to 1/1000
what are the shutter speeds for the 7D?
On the 7D the shutter speed options are 30-4,000 for 24fps or 30fps. If you're shooting 60p then it's 60-4,000.
wait so it can be either 1080p or 720p, it just limits it if it is 60p?
wow!! thats better than the HMC150!
right?!
woww! haha thanks!
