Dear All:
I physically cannot control the shutter on the AF100.
(i) I would love to use the SHUTR/F.RATE dial in order to change the shutter. The dial works fine with variable frame rates when activated in the settings menu. However, when the dial select button is set to shutter (verified with MODE CHK, so it is definitely not locked) then I cannot change the shutter. If I understand the instruction manual correctly then the user should expect to see the shutter angel in the display. This unfortunately doesn't work.
(ii) I can changes the syncro scan shutter speed within the scene files, however, the settings don't have any effect at all. So the waveform monitor stays the same with shutter 90, 180 or 270 deg.
Any ideas, is this a bug ??? Firmware is version 1.15.
