Shure FP23 to Tascam DR100
BillWojo
I need to hook up my Shure FP23 (same as a Sound Devices MP-1) to a Tascam DR100. The DR100 inputs are mic level if I want to use XLR cables. I will need to pad the input down but by how much?
I figure if I use the preamp and limiter on the FP23 and turn the preamps on the DR100 to low I will get better results.
There is a fellow selling 12" XLR cables with built in pads on Ebay for 20 bucks. Seems like it's what I need but I'm not sure how much attenuation I will need.
Thank you
BillWojo
You could also plug into the 100's 1/8" unbalanced line in. However you would need to build a balanced to unbalanced cable with 10 to 15dB of attenuation. L-pads are a little easier to build than a balanced H-pad.
FWIW, the DR-100mkII's XLRs can be switched mic/line.
Bruce, on the DR100 there is only mic level on the XLR inputs. On the later DR100MKII you can switch between line and mic levels for the XLR inputs.
Is there any disadvantage to padding down and using the XLR mic inputs? Also the Shure FP23 has no 1K tone signal, so what is the best way to set the gain staging?
Thanks again.
BillWojo
Typically, line level would be the preferred op level.. however, the line level input may just go through the preamp anyway (as is the case with most budget recorders). It's also 'unbalanced' so extended cable runs should be avoided. It also uses an 'unreliable' 1/8" jack so using the mic level XLRs would likely be the better of the two options.
Gain staging.. don't know, FWIW, I would assume the record level knob would want to be in the 50>75% range.
Rick, I agree 100% on the little frail 1/8 jack connection, that's why I want to use the XLR connection. I'm going to order the 1' long XLR to XLR cable with the built in -40db attenuator built in. As far as the gain setting on the DR100 I'm going to set the switch to low gain and turn the wheel to 50%. I'll use the limiter on the FP23 and turn it off on the DR100. I'll test it using the meters on the DR100 as the FP23 has no built in meter.
Thank you.
BillWojo
Ah, my bad. Shoulda read that more closely. Sorry.
The only disadvantage is that you have to go through the mic preamps on the DR100, which will be a stage of gain you don't actually need. If you could go line level, you could bypass the pres (I think the MKII does this, but I'm not positive). It's highly probable that you'll be perfectly happy using the pad, so go for it.
To have a mic input accept a line source, many mixers (and I'm considering ALL mixers, including consoles) you turn the inputs all the way down and use/engage a -20 dB pad. Different mixers may do things slightly differently (the separate line input might have a pad built in, or bypass the preamp) but in the end they're all doing the same thing, in my experience.
I'm sure there are exceptions, but this has been true enough times for me that I consider it a rule.
Hxd Ped, the original post is about feeding a Shure FP23 (same as a Sound Devices MP-1) to a Tascam DR100........ Not feeding line level into a mixing console
What I said still holds true. That's how you put line level into the XLR inputs on the Tascam HD-P2. That's not a console. I can't see why turning down the inputs and using a -20dB pad on the DR100 wouldn't work.
Portable recording equipment borrows much of their design from consoles and much of the best practices and concepts used with consoles can be applied to portable gear, such as gain staging for example. The DR100 has some of the same features that a large format console has. It has preamps, input trims.... and that's about it. But it's still a preamp and input trim before it goes to the actual recorder.
And the -20db pad on the Tascam DR100 is where (what page on the manual)? ..... I can't see it in the manual, yes it has a 3 level input control but still not enough to handle a +4 line level signal
Well my -40db padded XLR cable should be here in a few days. I'll give it a try and see how it works.
BillWojo
You're right, the DR100 doesn't have a pad. It's hopeless.
If only there was some other way to pad the signal. Perhaps with some small piece of equipment you could put in-line with the signal path. If only it could be conveniently installed into the XLR cable a person wanted to use. Sadly, no such thing exists.
If only. If only......
"If only it could be conveniently installed into the XLR cable a person wanted to use. Sadly, no such thing exists."
Four resisters (about a buck USD) and ten minutes rewiring/soldering the XLR. Which is probably the cable Bill bought.
That said, I still think it would be easier to just plug the mic directly into the recorder, the decrease in quality wouldn't be that substantial.. unless I missed something.
