I took over shooting at a wedding from someone else and the camera was set to 50p and shutter was to 1/60th. Anyway the footage looks jitery and sped up. Does anyone know of any software or other fixes that might help me out in the edit?
Not sure why it would look sped up, or jittery. You're normal in PAL-land is 25i, 50p allows you to playback at half speed slow, or normalize to 25i and playback at regular speed -- you're shutter choice was almost 360 degrees (the difference between 1/50 and 1/60 is insignificant) and in any case nowhere near fast enough to generate the nervous jittery look that high shutter speeds do ... So I can't really guess at what is wrong with your footage. Nothing in the specs you describe hints at a problem. Maybe post a sample ..?
I think that what you mean with 'looks like it has been sped up', is the 'normal' 50p look. I always have that feeling as well, especially after I watch something in slowmotion or 24/25p.
RGBaker is right, if you shoot 60p then at least set the shutter speed to 1/100 for it to look right.
Then if you still dont like the look, try 24p or 25p with shutter 1/50. That will look the most 'film like' and probably more like you expect it to be.
For a traditional look you try for 180 degree shutter. In simple terms that means at 25P you want 1/50th. For 50p you want 1/100th. But shutter speed is fractions of a second. Setting it at 1/60th is actually keeping the shutter open longer, not shorter. Setting at 1/60th for 50p will not give you jutter. If it was actualy 50i then 1/60th is a little faster than 1/50th, but you probably won't notice it. I think your problem lies elsewhere.
You need to investigate further. Did you drop the 50p footage on a 30p or 60p timeline? That can cause issues.
If this is intended for 60p or 60i final output the footage can be converted, but it will take a long time and likely require a lot of work. It can be done though.
I think I need to investigate a little further. To be honest I haven't actually seen the footage yet. I just got a call last night from the editor trying to explain what he was looking at and the difference between the two cameras. So I got him to check the settings for me. I'll watch the footage and also find out about the timeline he is putting it on.
