I'm in the process of shooting my events in widescreen. As most of you are aware, shooting widescreen using the DVX100A is a pretty simple thing. You either use the squeeze mode (which gives you approximately a 25% loss in resolution) or you use an anamorphic lens, which I do use on the 100A.
Here is my problem. I use three cameas when doing an event such as a wedding. I use my Panasonic EZ30 as a stationary camera for cutaway shots, and backup shots. All I have to do is put the EZ30 in the "Wide" setting and then when I import that footage into FCP, as long as I have the Anamorphic settings in the Capture and Sequence, I can edit all my footage in widescreen without having to render.
So my 100A with the Anamorphic lens and my EZ30 in wide mode cut perfectly in FCP. How do I get my 100 to match that?
The letterbox setting on the 100 places black bars on the top and bottom of the image and sets it as 16:9 into a 4:3 image for playback on a 4:3 screen. That's great for 4:3, but I want to cover the entire 16:9 screen so that when I cut from camera to camera, it all has the same aspect ratio (although of course not the same resolution).
Is there something that I'm missing here? It's hard for me to believe that the only way you can get 16:9 with the 100 is to either use an anamorphic lens or shoot it 4:3 (with a 16:9 mask) and then stretch it in post.
Any help on this issue would be greatly appreciated.
eric
eric
