Shooting under 50hz fluorescent lighting?
grjohnson
I did some indoor test footage at 24p in preparation for using natural lighting in an indoors scene. Although I was easily able to color balance to the flourecent lighting, I observed that there is a noticable "flicker" in the video, no doubt caused my the 50hz line voltage here (I am in Kuwait). What is the correct approach to correcting this problem?
My gut instinct tells me the solution will be found in the camera's shutter speed setting, but I have no idea what a correct setting should be using the 24p default factory setup on #6. Could someone who has encountered this problem please make a recommendation? It would be greatly appreciated.
Thank you.
Gaines
