mainstreetprod
I haven't shot for broadcast in over 10 years, so I'm a bit rusty. Here are the specs I've been given:
Format: AVI or MOV ONLY (MPEG2 Transport Stream)
• Size: 100MB or less
• Duration: 30 and 60 seconds- THESE FINAL RUN TIMES MUST BE EXACT FOR
THE TRAILERS TO BE APPROVED AND ACCEPTED.
Video:
• Resolution:
- 720 x 480 @ 29.97fps (NTSC)
- frame aspect ratio: 4:3
- pixel aspect ratio: 0.9
• Upper/Top/Odd field first
• Codec: AVC H.264 (Main Profile 3.0), MPEG-2 (Main Profile @ Main Level),
Uncompressed/RAW (except V210/10-bit), DVVIDEO
• Bitrate: At least 6Mbps (CBR).
• Luma should occupy full spectrum between NTSC standard 7.5 IRE black and white
level at 100 IRE
• # of frames for NTSC format
30 sec ad: 900 frames
60 sec ad: 1800 frames
• Text overlays should be title-safe
Audio:
• Samples: 48Khz, 16bits
• Dynamic Range: no greater than 7dB
• Codec: MPEG1-Layer 2, AAC, PCM
• Bitrate: At least 256kbps
• Number of channels: 2 (stereo)
Questions: Is the AF-100 set for 7.5 IRE by default?
Under codec, is it giving me a choice of 4 different codecs to shoot in (H264, MPEG-2, Uncompressed and DV)?
Any more advice to help me get this right the first time?
Video:
• Resolution:
level at 100 IRE
Audio:
