The HMC40 imaging block is unquestionably 4:4:4.If it was effectively 4:2:0 from the imaging block (with the HMC40)
Well, fortunately, this is answered very easily, by comparing the 150 against the 170. The question is whether the pixel-shifted arrangement of the HMC150 block results in higher-than-4:2:0 color sampling. I would contend that it certainly does, as evidenced in The Great Chroma Key Smackdown, where I put up specifically challenging footage from a variety of cameras, including the HMC40, the HMC150, and the HPX170. The HMC40 and HMC150 record as 4:2:0, the HPX170 records as 4:2:2. And yes, it can make a big difference.The HMC is basically capturing all the info from the sensors at 1080p 4:2:0 so you wouldn't gain anything in image quality by going to a 4:2:2 or better recording codec
Vericam has much larger sensors. Off the top of my head though, I think pixel count on the sensors is about the same (would have to double check to be sure). If it was effectively 4:2:0 from the imaging block (with the HMC40), that would cause problems. (4:2:0 progressive would convert to 4:2:0 for recording interlaced video pretty poorly.)
Look at the red hair dryer against the green screen. No question at all that the 170's 4:2:2 recording is quite superior to the HMC150's 4:2:0. That's the exact same chipset, same pixel-shift, same lens, same DSP, same everything -- but the 4:2:2 of DVCPRO-HD is just significantly cleaner than the 4:2:0 of AVCHD. (and that's after factoring in the pre-filter from 1920 down to 1280 in the 170!)
Therefore, I would say that it's quite likely that the uncompressed HDMI 4:2:2 output from the HMC150 is going to look better than the 4:2:0 recorded footage. Unfortunately I can't test that, but I think it's a reasonable assumption to make.
The ragged edge is the color sampling, both cameras were set to 1080/24p mode, exact same settings on each.
Locked down shot. How did you make your 200%? Zoom up in photoshop? I went to 200%, then screen-captured. If you resized to 200%, it would probably look a lot cleaner; I'm trying to show pixel-for-pixel accurate, just magnified.
I imported into FCP7 as ProRes LT and simply set the viewer window to 200% and took a screen grab. Then saved the screen grab as a jpeg. If I zoom to 800% it looks much worse of course and at that magnification you can see the discrepancy between the luma and chroma resolution resulting in a sort of black and white line around the edge of the letters, but it's barely noticeable at 200%.
Here's what 800% looks like BTW:
There are some differences in your testing methodology:
1) You converted to ProRes, which upsamples to 4:2:2 this will help to fill in the "stair stepping" to make it smoother when keying.
2) You're using different resize/zoom algorithms. Photoshop's zoom uses a point resize or nearest neighbor algorithm, you're using something like a bicubic or lanczos in FCP. Those larger "blocks" you are referring to in Barry's picture are intensified due to the resize errors
Here is your original 2x picture posted above, enlarged 4x with different algorithms , and cropped. Notice the larger block errors on the point resize, in addition to the edges
