Shaving my Leitz Leica-R lenses for use with the SpeedBooster
Samuel H
Major Contributor
In a previous thread somewhere around here I said my Leitz lenses were not hitting the glass of the SpeedBooster. It turns out, if you try to focus to infinity, some of them do: the Elmarit-R 35mm f/2.8 definitely does, the Elmarit-R 24mm f/2.8 would probably do if the protection bit around the back element was not already shaved, and the Summilux-R 50mm f/1.4 somehow manages to not hit the glass even though the bit extends farther away from that of the 35mm (it's wider on the 50mm, but it must be really close, so I shaved it too just in case).
I found this guide explaining how to do this. The basic stuff is explained there already, I just wanted to add a few comments:
* This was quite easy. It took me about half an hour to shave two lenses.
* Instead of lots of cotton and a bit of paper, I used a bit of cotton (just to protect the back element) and a lot of gaffer tape (to seal the lens and avoid metal bits going inside). After I was done with the file, I vacuum-cleaned the lens, got the gaffer tape out, vacuum-cleaned again, brushed while vacuum-cleaning, and I was done.
* I expected that, since the protective bit is made of metal, grounding it down would take a lot of time and effort, and it would be risky. It turned out to be extremely easy on the 35mm (the bit is made of soft metal that is black on the inside; it took me less than a minute to take nearly 2mm out of this one, so the risk here is that you may overdo it and scratch the back element; as soon as the file starts hitting the gaffer tape, stop!) and not really difficult on the 50mm (the bit is made of much stronger metal, that is silver-colored on the inside; still, it took me just about 5 minutes to get over 1mm out of it; the risk here is that if you're not patient and use too much force, you may damage something; so take your time, this is an expensive lens).
More comments and pictures of the process here.
Well, kind of, but I'm used to it (I have my Elmarit-R 24mm f/2.8 open right now: I bought it a month ago, it's badly assembled and it doesn't focus to infinity; like most Leicas I've bought, actually...).
