Shallow DOF Video Footage W/ Anamorphic DVX100A
redcap
At the end of a shoot I was doing a few months ago a PA I was working with wanted to play around with a camera and get some "shakey cam footage."
I said what the hell and gave him a few pointers and he came out with this. Of course I didn't have anywhere to put it in (for the project) but it came out looking really neat. He was standing about 3 or 4 feet away and zoomed in pretty close, if I remember correctly.
A little bit of background - I was using the panasonic anamorphic adaptor, was on scene setting 6 (24pa) had OIS off, auto focus off, auto iris off. Not sure about the exposure settings, however. I don't remember if I had turned all the lights off, or if I had left the softbox on or not. I might have, but most of the light was coming through the window.
Here it is : note - no color correction or anything applied. Those first few frames had an ND filter on it, ignore them...
http://www.redcapmedia.com/movies/shallow_dof.mov
Um ...I don't think the file works...I'm getting an error message when opening it in QT. Even if I download it i'm getting an error message.
Check the file
Pete
Links works here on OS X 10.3.9, QT7. Looks like good "shakey cam" to me : )
Care to elaborate what shutter speed was used in this example?
Here's some screen caps if the movie doesn't work. QT isn't behaving today. Thank you QuickTime.
I want to say i/24, but I could be wrong - nonetheless its slower than normal. I was pretty ignorant about my camera back then; learning mostly through trial and error.
Thanks for the post Redcap. Unfortunately this is not the best example because your background is overexposed and we are not seeing a clean separation between background and foreground...
The grabs look pretty good, however, I think you could achieve a sharper image using the stretch mode. With the Anamorphic, it doesn't seem like you have a sharp focus on these.
Here is an example of a shot very similar to yours. IT was shot in Squeeze mode, and was actually softened in post.
I am not saying "My grab is better than your grab".
I am saying that the anamorphic adapter does not do well when trying to achieve shallow focus. Personally I use squeeze for any tight shots, and when available, I will use the anamorphic for wide shots with deep Dof. That is where it really makes a difference. In close ups, and head shots, even perfectly focused Anamorphic footage is very hard to discern from stretched or uprezzed letterbox footage.
