Shallow DF with HMC40
24 seconds.
Others have too creamy bokeh at a wider FOV for the CU. Not possible with a small sensor.
Plus there is a vignette on the shot that's probably from an adapter.
24 seconds is one of the 2 made with the HMC40 the vignette was made in post no adapter was used, and the OTHER is at 15 seconds shot also was made with the HMC40
Believe it or not, I was very close to saying 15 seconds too, but you only said one shot.
You use that HMC well!
Yes in fact the one at 24 seconds because of the post production effects is not as evident but it was made with the HMC, The one at 15 shows the splendor of the HMC Optics.
Thank you for the comments.
