basspig
I shot some timelapse and some normal frame rate footage of cloud formations this evening and when I imported it into the NLE, I noticed that it looked like SD upscaled to 1080, rather than 1080. I also noticed some horizontal magenta lines in some of the frames.
I've shot beautiful timelapse in the past with the FS7, but this is the first time I attempted it with center crop mode. What it looks like is a crop of a JPEG image, in terms of quality. The first thing I noticed was jaggies on the cloud edges. The second was the magenta "noise" lines against the blue areas.
At first, I thought it was an artifact of using S&Q mode, but even the normal 23.98 FPS footage I shot has the same artifacts.
Does the CODEC compress first, then crop the image before saving? Because that's what it looks like to me. I've only seen macroblocking this bad on XAVC footage, zoomed in 400%.
I know at least one other member of the forum has reported this same artifact under similar shooting conditions, so it may be a limitation of center crop mode.
