Setting to record 1080p 60p
eddavid
Carbonite Member
anyone know what setting you should be on the F3 to record 1080p 60fps to a device like the Cinedeck or the Gemini?
actually answer seems to come from dvinfo.net
The Cinedeck only supports 1080p/60 with 8bit Cineform codec. No other codecs are supported for this frame rate.
When “Dual-Link & Gamma Select” is set to “1.5G YPbPr422 & Video”
OTHERS menu “System” HD SDI output format:
NTSC Area/
NTSC(J) Area
Country Format:
HQ 1920/59.94i
Video is output as follows
SDI A connector:
1920 × 1080/59.94P@1.5G
SDI B connector:
