Servo zoom noise.
hal9000
I got the new DVX100AE just yesterday and as usual I read manual after touching all buttons...
When I took my cam first time, I place the UV filter (this I did well) and after I turn focus ring (to feel it) as well as zoom ring (about two times). This zoom ring turned a bit hard.
Reason was that switch was in SERVO instead of MANUAL.
Of course in the manual is written do not turn the ring while you are in Servo.
Now, I want to check with some of you following. You turn the cam on, put in Zoom Manual. Turn the zoom by hand.
Connect SERVO. When y click the zoom lever I heard a "clack" (like coupling noise) and after it works fine without noise.
Do you think I damaged the servo mechanism because of two turns by hand in SERVO position ?
Thanks a lot.
Re: Servo zoom noise.
sometimes mine makes a gear engaging noise when i swith to servo zoom , but havent torqued it in servo mode.. it works fine. i think its just when the lense is in a certain position , and the gears dont quite line up when you switch, and then they click into place. ive never worried about it.
