Vitaliy Kiselev
Carbonite Member
Special notice! All this info is not intended for end users. You won't find here any useful info other than one that could damage your camera.
Temporary service mode:
1) Non-empty SD card must be installed
2) Check that single shot mode is selected.
3) Before trning on camera press:
a) DISPLAY+FILM MODE for G1 and GH1
b) DISPLAY+AE LOCK for GF1, G2, G10
4) Turn on power.
You must see ROM BACKUP option in settings menu.
Error code table in this mode:
1) Press left arrow + MENU/SET and hold them, plus press
a) FILM MODE for G1 and GH1
b) DISPLAY for GF1
c) AF/AE LOCK for G2 and G10
If you repeat error code table method one more time for'll be in CAMERA INFO screen.
Pressing Display will show you CAMERA INFO 2 screen.
Permanent service mode:
WARNING: You can ONLY get out of this mode by re-initializing your camera! You are responsible for your own camera!
1) Enter in temporary service mode.
3) Press "Play" then find a movie and play it by pressing the Up button.
4) While holding "Up" and "Film Mode" turn the camera off.
As the camera powers off you will see the yellow triangle with the "!" instead of the regular Lumix graphic.
When you turn the camera back on, you can always access the error and counter screens using the same steps as temporary mode:
1) With the camera on (from last step), press and hold the left arrow button and the "Menu Set" button together. Keep holding them!
2) While these are pressed, press "Film Mode". You can let go of all the buttons now!
The difference is that you never have to hold display and film mode when powering on,
you get the ROM Backup option all the time, and you have to re-initialize to get back to the normal operational mode.
Advanced service menus (by Path):
I have finally figured out the key presses to get to the actual service mode, the one with all the 3 character options.
Each of those options is a different test, and each has an "F" next to it, which can be changed to an "O" using the "Delete" button.
The "O" turns on the test, and all the ones turned on will execute in order upon pressing the "Display" button.
To get to this mode, your camera must be in the "Permanent Service Mode" I previously described...
the one where your camera consistently displays the yellow caution triangle when powering off the camera.
From here it is a simple matter of:
1. Power off the camera.
2. Turn the drive mode lever to Burst mode.
3. While holding the "Film Mode" and "Display" buttons, power on the camera.
Done. You will see "SERVICE MODE" at the top, with the options for "NORMAL : >" and "ALLRESET : FILM+DEL".
From here, you can press the "Display" button to get to the screen with all the 3-letter test options.
Be careful, as some of these tests are quite tricky to use, and if you enable one I don't believe there is a way
to turn it off until the camera passes the test.
This is especially tricky for the "KEY" test which is a test of every single button on the camera and maps each button
to an alphabetical character.
Once this mode is enabled, the "ROM BACKUP" menu will have the "! > LUMIX" option enabled and no longer grayed out.
List of all three letters tests (I'll add screens and descriptions of each later):
4) Turn on power.
b) DISPLAY for GF1
EVF KEY OIS BF SHT ISO WBL WBH LIN STB LED COL WKI
DUW DUT BKI RES THE CLK SEN TNO WFC MAC IND TRA AF
IRT IRZ RESET RS2 EST KY2 LCD PWK
--- SWF BBC FBC AFS AES AFA SEP AEP OVF IR1 WBM
IR2 DST RE2 RE3 RE4 AGE LAF EYE OUT PZM EMC MOV PLY
