I've been using FCP daily for 5 years. Currently running 4.5 on a G4 dual 1.25ghz w/ 2G RAM. Shot a short film on DVX100 in 24ap mode.
Problem. Tried a 'capture now' function directly from the DVX100, time code kept breaking (more frequently as tape progressed, ** it also started capturing 24p footage as 29. I'd try again and it would capture as 24 (same footage) ** . Eventually it was so Bad I gave -up. I retrieved my DSR-20 and tried logging and capturing from that - the exact same problem persisted. Thinking it was a computer/system issue I tried capturing the footage from the DSR-20 AND the DVX into a different computer system. Then I tried it again on yet another system - same 'ERROR - dropped frame' every time.
I am pretty sure my DVX100 recorded bad TC or cadence info while I was shooting.
QUESTION. IF the problem is inherent to the tape what can I do? I thought about cloning the tape either from the DVX100 to the DSR20 or vice versa. Can you preserve the 2:3:3:2 cadence info in a cloning operation? would I need to clone between two DVX100's? Does the DVX100 record cadence info while in VTR mode or only in camera mode?
