Justin Reade
I am having difficulty determining what sequence setting to use in Final Cut Pro 5.1, for footage that I have shot in 1080i/24pA.
When I choose the option 1080i/60 with a 29.97 editing time base from the "Easy Setup" menu in Final Cut, the clips import perfectly and I don't have to render (which I don't understand at all, since I shot in 24 frames per second not 29.97). However, when I change the editing time base to 23.98, I have to render all my clips, and any subsequent EXPORT of my footage using Quicktime Movie yields a very CHOPPY and SCREWY .mov file. Shouldn't footage shot in 1080i/24pA NOT BE REQUIRED TO RENDER when I'm in a 23.98 timebase? Therefore, I'm totally confused in that department.
I also realized that when I choose 720/24p with a 23.98 editing time base from the "Easy Setup" menu in Final Cut, I have to render my clips (obviously), but the exported quicktime movie is PERFECT.
What the hell setting is correct for 24pA footage shot in 1080???? Shouldn't there be an Easy Setup setting for 1080i/24p with a 23.98 timebase. Would seem logical to me, but it's not available........
Thanks for the help.
Justin.
Justin.
