LiamR
I've found this spec of dust/something, and it's not on my lens, because I have tried 4 different lenses and it showed up in the same spot, it's obviously not on the LCD screen as it has come up in footage, so it can only be on the sensor, I cannot visiby see it on the sensor, but a good clean should fix it.
So, I have never cleaned a sensor before and I need a bit of guidance on how to... only problem is, I shoot a pilot TOMORROW. So it's going to be hard to get out to any shops and buy any cleaning kits, so what around the house can I use? I have my cloth/towel + lens cleaner for my lenses, could that be of some use? I will try and not push on the sensor at all to prevent damage that way, any advice would be good advice, thanks
Here is the dreaded mark.
