Price $1400
This mic is in excellent condition! The blimp has a crack on the rim that can be easily fixed with a piece of tape (see pic).
Comes with
The MKH 70 is a lightweight long shotgun microphone. Its excellent directivity is particularly suited to applications undertaken in difficult conditions, such as high background noise and distance microphone positioning. Its frequency-independent directivity prevents sound colouration from off-axis sound sources.
Exceptionally low inherent self-noise
Transformerless and fully floating balanced output
Infra-sonic cut-off filter
Symmetrical transducer technology ensures extremely low distortion
Switchable pre-attenuation, switchable roll-off filter and switchable treble emphasis
Rugged and weather proof
Black, anodised light metal casing
Specifications:
Comes with
- Microphone
- Wooden case with graph
- Rycote blimp
Specifications:
| Transducer | Interference Tube Condenser |
| Polar Pattern | Supercardioid/Lobar |
| Frequency Response | 50 Hz - 20 kHz, (-3 dB) |
| Dynamic Range (Typical) | 119 dB |
| Signal-to-Noise Ratio | 88 dB |
| Maximum Input Sound Level | 124 dB, (@ 1 kHz) |
| Power Requirements | Phantom 48v, (+/- 4v) |
| Output Impedance | 150 Ohms |
| Output Connectors | XLR-3M Type |
| Pad | Yes, -10 dB Pre-Attenuation Switch |
| Low Frequency Roll-Off | Yes, -5 dB/Octave @ 100 Hz High Frequency Emphasis: +5 dB/Octave @ 10 kHz |
| Applications | Film, Video and Broadcast Production. |
| Dimensions | 16.1 x 1" (410 x 25mm) LxDiameter |
| Weight | 6.35 oz. (190 g) |
