Sennheiser MKH 50 vs Rode NTG3 - OUTDOORS
‘With news, I often felt I was only capturing audio for the image, and being for broadcast, felt more obligated to use the shotguns, to get a more isolated and focus sound of whatever was center frame.’
‘In documentary, I often had closer access to the subjects, and wanted to record conversations and allow some of the world to bleed in more naturally, so a hyper gave a better blend, where whoever the camera was pointed at got the lion’s share of that audio, but someone else just off axis didn’t sound all weird, just more quiet with out being completely cut off either.’
‘‘If you’re basically happy with the 4053, rather than replace it with a similar mic, why not get a different/longer mic, so then you’ll have a couple to use. Basically, the 4053 for “indoors” and something like a short shotgun for “outdoors.” ‘
Thanks to James and Jim for those comments above particularly, although the whole thread has been useful.
It seems like long term I’m looking for two (on-camera) mics - One with minimal off-axis pickup and one with minimal off-axis colouration.
I’ll probably get something like an MKH 50 in the future, precisely for situations like the documentary scenario described above. For now though, I’ve decided to get its more… aggressive sibling for news / broadcast. So presumably this means a shotgun or short shotgun.
I’m most likely going to get the Sanken CS-M1. I’ve read talk about the CS-3e’s ‘reach’. Does this also apply to the CS-M1? It’s a very short interference tube. It there anything else I should be looking at? I’d still consider something like an 8060 - would it be a huge step up from the CS-M1? Or totally different?
I know a lot of people consider it ridiculous to spend so much on on-camera mics (e.g. 8060+MKH 50) but I don’t. I’ve got highly specialised lenses that cost way more than an 8060. And a decent mic could contribute something to every project for the next decade or more.
Requirements:
- On-camera mic with decent isolation (though obviously there are limits to how narrow the pickup pattern should be for an on-camera mic).
- A bit of rear pickup shouldn’t be a problem as rear of mic will point to my chest most of the time.
- Not completely terrible with indoor reflections.
- Excellent humidity tolerance.
- Small size and low handling noise a bonus.
I am unable to test any of these mics, that's why I'm asking here. From comparisons online, the CS-M1 sounds good to me although it lacks the nice warm bottom end of the CS-3e.
For dialog, a low-cost mic placed in close proximity to the source will sound significantly better than a mega-buck cam mic a few meters or more away.
Or even a decent lav! Let's just assume that no audio from a few meters away (what am I doing a few meters away? Buying a sandwich?) is going to be useable. This will be an on-camera mic, 90% of what it records will never be used. Very occasionally though, it will end up catching important audio, most likely vox pop from within 3 feet, probably in a noisy environment.
The Sanken CS-M1 seems really cool. I may buy one this year (I already own several of their lavs and a CS3e). But it's $900. For how you intend to use it, is it really noticeably better than some lower-priced alternatives (that I think have been mentioned already in this thread...AT, Rode, Deity come to mind)?
Here's a list of Sanken's US and Canadian dealers (I'm assuming you're somewhere around those two countries):
https://www.sankenmicrophones.com/buy/
If you could get to one of those places and compare the CS-M1 to a couple other less-expensive mics, that'd really help you make a solid purchase. Bring your camera and a card, try out the mics in the store, step outside for a few minutes to get some noise, have one person stand directly in front, then have two people (or just one off to the side so they're not directly on axis), then listen to the recordings on your computer (bring your laptop and headphones). Then buy the mic that works best for you and your budget, and get the compatible mount (perhaps Rycote), etc from that dealer.
Or see if one of those places will rent a CS-M1 to you for a few days.
"For how you intend to use it, is it really noticeably better than some lower-priced alternatives (that I think have been mentioned already in this thread...AT, Rode, Deity come to mind)?"
Possibly not. Unfortunately, I'm in Hong Kong and even the official Sanken distributor doesn't carry the CS-M1 for some reason.
It is a bit of a moving target for me.
In this room with these voices, at that mic placement, I prefer the DPA 4018 with no filters. It seems to help tame the ssss and shhhh sounds. Except.... at lower volumes, it gets more difficult to hear the articulation. So, at higher levels, I preferred the DPA no filters, and at very low volumes, I liked the Schoeps.
When the DPA has the low cut and high boost filters engaged, I find it is not as nice on the sibilance, lip smacks, clothes rustles, hard swallows, and plosives. That is sort of the beauty of the SChoeps, very articulate, full, and almost excessively lively, but never harsh or dark. very open and present sound that retains a naturalism.
The room has that odd reverb to it. The DPA without any filters seemed to sound better in that regard, but could just be the lower frequencies masking the issue? The Schoeps always had a low cut engaged. Whether 30hz at 1, or 70hz at 2.
I think the Schoeps MK41 can sound fuller without a low cut filter applied. so, difficult to say.
Woman 1: Either mic, all filter settings worked well. I did prefer the 4018c with no filters the best.
Woman 2: she did not seem to have much lower register in her voice, so all of the mics were naturalized, and it came down to the sound of the sass's for me, and I preferred the SChoeps.
Woman 3: DPA was only in low cut and high boost mode, and I think it cut a little thinner sounding than the Schoeps
Woman 4: The Schoeps sounded a bit boxed in, and the DPA handled the acoustics and proximity better for the voice in the situation.
Man 1: The Schoeps had a more open sounding voicing. The DPA was "warmer" or fuller, but also lent a more "nasal" sound to his voice. However, the reverb of the room sounded better in the DPA. The reverb is still there, but it is less noticeable for whatever reason.
DPA is interesting, it sounds like a technically better mic, but perhaps misses some of the sparkle and silk of the schoeps. Notably, in a very subtle way, when the DPA has the low cut and high boost applied, it seems to be ever so slightly behind the schoeps in sounding nice, and that is with the CUT filter on the Schoeps.
But, the DPA is really flat, and it can be tuned to taste by a skilled sound person.
DPA seems to have that technical ruler flat sound that the original MKH series seemed to aspire to in the tape age, but the DPA being more well suited in the digital world.
The DPA seems to be able to handle the low cut high boost without ever going as far as the Nuemann KM184/185 in terms of slicing. The Neumann's can cut into a mix, when recording music, but are a bit unnecessarily aggressive in dialogue pickup. IMHO.
Road Trip! Sonora Pass is open! Destination, Trew Audio, Burbank. Purpose: listen to and purchase a microphone. Also drool over Lectrosonics and other fine gear.
James and I will get together and have a microphone shootout between the MKH 8050 and the CMC 1/MK 41 (and others I suppose) and then I will be convinced one way or the other which one to buy. Anybody want to join us? James, PM sent.
Yes! Looking forward to it!
good times!
was a good and clear reminder of the hairs we split when comparing gear online! will have to do this again! thanks for setting it up @PaulF!
