Sennheiser Lav mic problems. Or is it interference?
chasford
I just had a shoot where my Sennheiser EW 100 G2 system started acting up. The first 45mins of the shoot was in a hallway and there were no problems with the sound. Then we moved into a conference room where there was audio/visual equipment present. I didn't notice if the a/v equipment was on or not. After five or ten mins. I noticed that the audio would momentarily drop every 4 or 5 seconds. I'm not sure but it seemed that the time between the drops began to get shorter and shorter, or maybe I was just becoming more and more aware of the drops. The RF and AF lights would blink at the drops. Luckily I could get enough sound bites to do what I needed to do but now I'm not sure if the fault is with my system or interference from the a/v equipment in the room. I have never experienced interference like that before and to be honest I'm a little spooked about my equipment. I checked the system when I got home and there were no drop outs. Could it be that it's my equipment going bad and it only starts after the system has been on for a while? When I tested my equipment at home I did leave the system on for about 30min with no dropping. Or was this interference and if so does anyone have suggestions on how to get around the problem?
Did you try other frequencies? Why did you not check if anything in the room was on? Was your squelch on? A sound bite would us help diagnose.
