charles
I thought I'll give it a run here first before putting it up on ebay. So if you're interested then holla at me:
1. 3A top stage (worth between $750 - $1000) Selling for $730. Now this stage is missing the clamp down nugget that usually comes along with it but if you're interested in this stage then I would call White house as they have only one in stock. I talked to Derrick and he said it costs $65. This includes the screw as well. So if you're interested in this stage give him a call or an e-mail and tell him you're interested in buying the nugget as you will be buying a 3A top stage from me. He'll know whom.
2. Baerbel dove-tail for the 3A top stage. It is unused and cost around $150 brand new. I'm selling it for $130
The dove-tail mounted on the 3A top stage:
3. EFP vest/arm bracket with female socket block(worth between $250-$300). Selling for $235.
4. Model III j box with the level sensor. Worth? Not too sure, so just make me an offer. Model III j box with the level sensor. This was taken from an old model III sled. I bought it with the intention of using it for something else but decided I did not need it any more. This could be something for newbies or someone with the ability of rewiring it to fit a present setup.
I was told on the Steadicma forum that one could..."If you are good in electronics or know someone who is. these boxes can be very handy.
I used the smaller part, with the electronic bubble level, to make a level indicater with LEDS. This is very easy, with the right chip, LM 3914
(http://www.national.com/mpf/LM/LM3914.html) you can make a nice little box, which is sensitive to the angle and which you can mount on your rig.
I build this when I sacrificed my IIIa system and still use this on my LCD, it has 4 HiBright LEDs on either side of a big Green LED and it is very helpful to see from the corner of your eye.
The bubble level is sensitive to speed changes so not always reliable but until now, I have been very happy with it."
I guess it is worth a try if you are good with electronics.
