justmarvin
Brand new, sealed. Awesome package, speaker set up, screen, wires, 3d glasses, etc. Estimated list value around $2,999. Hit me up with your best offer if interested.
This package includes the following items:
*OPTOMA DLP HD66 HD66 720p Home Theater 3D-Compatible Projector
*OPTOMA BG-ZD101 DLP Link 3D Glasses (4)
*PEERLESS PJF2-UNV-S Spider® Vector Pro Plus™ Universal Projector Mount (Silver)
*SHERWOOD BDP-5004 Blu-ray Disc™ Player
*VUTEC EVPV4580 Porta Vu Riser Manual Pull-Up Screen
*PINNACLE SPEAKERS S-FIT SYS 6000 6-Piece Home Theater in a Box with 10" Powered Subwoofer
*ZAX Cable Starter Kit
*SHERWOOD RD-8504 7.1-Channel, 100-Watt Dual-Zone A/V Receiver with Video Upscaling to 1080p
*MONSTER CENTRAL MCC AV 55 6-Device Home Theater Controller AV55 Universal Remote
500 feet of Bulk Speaker Wire
*MONSTER CABLE 132785 HDMI Cable Bundle
2500 ANSI lumens
3D compatible
Native 720p (1280 x 720) resolution
4000:1 contrast ratio
Features DLP® & BrilliantColor® technologies by Texas Instruments®
HDMI™, VGA in, S-video, composite video, stereo audio in & RS-232 connectivity
Max lamp life: 4,000/3,000 hours (STD/bright)
Dim: 3.98"H x 11.28"W x 7.6"D
Weight: 5.1 lbs
1-year warranty, 90 days on lamp
3D glasses with 3 interchangeable nose pieces
120 Hz shutter style
Compatible with Optoma® DLP Link enabled projectors (OPTEW536, OPTHD66, OPTGT360, OPTGT700)
Requires 2 CR2032 batteries
Adjusts to fit virtually every projector on the market
Unmatched versatility
Design allows for proper projector ventilation
Theft-resistant Armor Lock™ security at all connection points
Mount flush or with 1.5" NPT schedule
40 pipe or threaded rod
Quick release feature for easy maintenance
Includes 4 adjustable legs to align with the projector's mounting holes & a variety of mounting screws for compatibility with most projectors threaded inserts
Holds up to 50 lbs
Cable management
UL listed
Blu-ray playback up to 1080p
Scales standard DVDs to 720p, 1080i, 1080p via HDMI™
Plays CD, DVD & Blu-ray Discs™
Deep color
x.v. Color™
HDMI™ 1.3, component & composite outputs
Front panel USB host input
192 kHz/24-bit audio DAC's coaxial digital audio output
Dim: 2.19"H x 16.94"W x 10.24"D
Designed for portability
Matte white fabric
Elegant black aluminum housing
Pull-out telescopic bar
1-year warranty
92"
45" x 80"
16:9 HDTV format
1 PINACSUB125 Subwoofer
4 PINSFITSAT150 Satellite Speakers
1 PINSFITLCR250 LCR Speaker
Ideal for the retro fit & MDU markets
Includes high-quality subwoofer interconnect cable
100W RMS per channel with < .2% THD, 6Ω per channel
DTS-HD™, Dolby® True HD, DTS 96/24™, ES, Neo6, Dolby® Pro Logic IIx, MLP (DVD-A)
3-in, 1-out HDMI™ v1.3 repeater
Video scaling to 1080p
Supports PC/cellular phone audio streaming via (optional) BT-R7 Bluetooth® plug-in
SIRIUS® ready
iPod® ready
Totally discrete amplifier stage for all channels
Multi-source, dual-zone operation
8 DSP surround modes (theater, hall, stadium, etc.)
192 kHz/24 bit audio D to A converters for all channels
Automatic speaker setup with supplied microphone
SNAP™ Room EQ
Quadruple crossover
Anchor Bay ABT-2010 converts all video to display resolution including 1080p (via HDMI™)
Cinema EQ
Digilink-i™ compliant
AM/FM tuner
30 station presets
7.1 channel direct input
A/V synch delay by input
3 A/V inputs & 2 A/V outputs
2 component video inputs & 1 output
8 analog inputs (including tuner)
Analog output
Composite & S-video with 3 in & 2 out
2 coaxial & 2 optical digital inputs
Optical digital output
Dim: 6.69"H x 17.13"W x 15"D
Model No. MCC AV 55
Controls 6 A/V components
Touch sensing user interface
Simple controls, keypad & special function key for ease of navigation & use
Full learning remote
Preprogrammed codes
Smart volume punch through for component volume control without changing source mode
Correct components are turned on when appropriate mode button is pressed—DVD button turns on DVD & TV simultaneously
Durable shot translucent acrylic top case
High-quality, durable rubberized back coating with non-slip grips
Console/tabletop design
High-quality construction in high gloss black
Dual full amber & blue backlighting indicates which source is being controlled
Zax Cable Starter Kit
With more than 25 years of experience, ZAX creates high-quality cables and connectors that surpass expectations, and the ZAX Pro Series & Select Series Cables are no exception. With this cable bundle, you can have everything you need to complete your home theater setup in a single package.The kit includes:
6-m subwoofer cable
4-m digital optical TosLink® cable
1-m, 2-m and 6-m HDMI™ cables
2-m digital coaxial audio cable
2-m S-video cable
4-m RCA audio cable
4-m composite A/V cable
2-m component cable
3.5mm plug to 2 RCA plugs Y-adapter
Polarized
Consumer grade
Clear, flexible PVC jacket
Black plastic spool
16 gauge
Monster Cable 132785 HDMI Cable Bundle
Minimum 10.2 Gbps capable
8 ft HDMI™ Cable
Monster® Mini Screen Clean Kit
Monster® AV600 Power Center
2500 ANSI lumens
3D compatible
Weight: 5.1 lbs
Holds up to 50 lbs
Cable management
UL listed
Deep color
x.v. Color™
Matte white fabric
1-year warranty
92"
45" x 80"
16:9 HDTV format
SIRIUS® ready
iPod® ready
SNAP™ Room EQ
Quadruple crossover
Cinema EQ
AM/FM tuner
30 station presets
Analog output
Model No. MCC AV 55
Preprogrammed codes
6-m subwoofer cable
2-m S-video cable
4-m RCA audio cable
2-m component cable
Polarized
Consumer grade
Black plastic spool
16 gauge
8 ft HDMI™ Cable
