hambulance
Hello FS700R O7Q users.
I am focusing on my audio gathering skills, as I currently see that as my weakest production area and giving it some practice. I have a SD-302 on the way and have been learning about how good clear pre-amps, using and setting limiters and high pass/low cut and all those cool things to get good dynamic range in audio capture with my images.
I'd like to get some advise from someone out there, that is knowledgeable, if they exist and read this.
The FS700 has a line input options (on L+R), which I assume bypasses it's pre-amps (or is at a level that negates noise from them?), and I'm aware that the camera records maximum 48kHz / 16-bit. I read that the O7Q recorder in Prores HQ is paired with 48kHz / 24-bit audio.
So as far a thinking of a typical connection setup I'm wondering what would be the most rigours setup to record audio (embedded in the video file) at 48kHz / 24-bit using the O7Q.
Using a SD-302 field mixer; which has 2 balanced xlr outputs (L+R).
Typically I would imagine these would go into the FS700 inputs at line level (and set accordingly).
When the FS700 is connected to the O7Q recording 4K2HD or the upcoming prores flavours, is there any kind of bit depth limitation happening (to 16-bit) into the O7Q, as the FS700 maybe has a ceiling of 16-bit depth??
If I wanted 48/24-bit would I need to bypass the FS700 and go direct audio connection into the O7Q. I've had strange results using the 3.5 mm (I'm assuming unbalanced) jack into the O7Q only because the device is getting Audio from the camera into the main SDI port.
So my questions are:
How could I get a balanced stereo input into the O7Q at 48/24-bit??
Should I use one of the other SDI inputs? Is there some kind of stereo XLR to SDI adapter I might need?
Or is there no bit-depth threshold/limitation as audio signal goes through the camera?
Any solid advise is greatly appreciated.
