I know that using the Picture Profile function you can effectively "dial in" any color temperature you like using the WHITE function. However, unlike other cameras I've worked with, I can't seem to "SEE" the changes I'm dialing in until I save and call up the particular picture profile again.
In other words, I'd like to be able to see the changes the dialing is making before I lock it into the profile, without having to keep saving the profile,
calling it up and then seeing the end result.
Is this possible? Thanks.
