M Manuel Active member Jun 2, 2009 #1 Hi short question: is a 16mb sd-card big enough for saving the different presets or updates?
Spec-Comm DVXuser Sponsor Jun 2, 2009 #3 Firmware updates require at lease 32MB of free space. I would recommend at least a 64MB SD card if you plan on using it for firmware as well. Andrew Hoffman
M Manuel Active member Jun 2, 2009 #4 Thanks. I just found an old 16mb card and thought I could use it when I get the HPX171. I have also a 1 gig card which I will then use for firmware but this card is usually for my fotocamera but for the normal use the 64 mb will be fine. Perfect. Manuel
