Is this an animation or a photograph? It looks like it came from an animation package. The colors in it have a very green-yellow cast. To get something in that color range I'd start with the FLUO coloring. Then play with color temp and color phase. The colors are slightly desaturated. So turn the color level down a bit.
The blacks are really blocked up. So lower the Master Ped to do that. But there is also some fine detail in the pattern on her shirt. You'll need to arrive at a balance between the gamma settings and the lighting. This image has 35mm DoF with a shallow aperture. Are you going to shoot with a 35mm adapter?
The detail in her hair is lost, as well as in her eyebrows. So you will want to modify the detail settings to get a very soft image. If you shoot with a 35mm adapter then it will get this soft with little help.
I'd start by getting the gamma and blacks/whites correct, then go after the color, and finally, go tune with the detail settings. You might not be able to get the exact coloring you are looking for. But you can probably get close enough to color correct in post to get that look.
