Worzel Gummidge
Carbonite Member
Nothing dramatic, just a simple test for any curious minds about what some C-Mount lenses are like on the GH4.
I don't make these tests everyday. Good to know you appreciate my effort anyway, so sorry this inconvenienced you Khachik.....Why creating different threads for each lens instead of making one and updating it/bumping it?
Ok here is where I have a problem with C mount lenses. They require the use of ETC. ETC uses the center portion of the sensor which means you do not gain any of the advantage of the larger sensor. You are basically using a 2/3" 1920x1080 sensor with the reduced sensitivity that one normally gets when using ETC. These C mount lenses tend to be brighter at f1.8 but since the sensor is no longer as sensitive you end up with noise that is worse than using a f4.0 lens with the full sensor. So in reality you don't gain much at all in terms of low light. Sure you get a power zoom but the softness is worse than any lens I have ever seen.
ETC on the GH cameras really starts to look ugly at ISO400. This means you end up with less usable range to work with than you would be shooting with a f2.8 m43 zoom lens. If these thing could fill the sensor it would be a totally different story but alas they do not. ETC can be a serious reduction of quality and low light capability and any lens that has to use it is really at a big disadvantage.
Now if this is just for a unique look then that is cool but I would never consider these a solid production tool if quality is a concern. You would honestly get much better results from a good 1/3" or 1/2" video camera with a built in 12x or 20x zoom lens designed to work with the camera at optimal resolution.
