HPX250: Scene/User Saving
NorBro
Major Contributor
Hi. I would like to have two setups available at all times that I can easily switch back and forth to.
1080/24p and 720/60p
The only way I understand this to be possible is by saving BOTH - the scene (framerate) and user (system) files to an SD card and then loading them individually, right? There is no way to use the scene file knob where I can just switch to a different F# and have both?
For example:
F5 - 1080/24p
F6 - 720/60p
Also - a little off topic - with P.A.P 1 - is it recommended to not move the camera (static shot) when using this setting or having virtually no motion in the frame as well (i.e, interview)??
Thank you. Happy Easter!
You can't do that as it requires a reboot to change formats.
I've used P.A.P 1 for interviews without any problem other than I noticed in a green screen interview I needed P.A.P 1 on the subjects hair needed tweaking to make a clean key in FCP X. Everything else I've keyed in FCP X was a "one button push" perfect key. Maybe P.A.P 1 had something to do with the hair thing, but it was very easily fixed in FCP X. Who knows if P.A.P 1 had something to do with the hair thing???
