Turn down "DETAIL" as low as it will go and use "THIN" vertical detail. Another thing that you have to consider is that most TVs are not calibrated (and have probably never had their picture settings adjusted) so there will probably already be edge enhancement turned on for the display. One application of edge enhancement is bad enough so there's no need to do it in-camera.
Also, shooting in 24p or 30p may be better than 60i, but it depends on what kind of look you want.
I highly recommend using a "detail" setting of -7. If you are absolutely sure that you need edge enhancement in the video it would be better to apply it in post-production so you at least have the option of keeping the video unchanged. Edge-enhancement will make the scaled HD version look worse. If you need to use "detail" to focus, have two scene files, one for focusing, and one for recording (assuming that you don't need to rack focus during a shot).
remember, as i just discovered, turning up sharpness turns up noise as well,
when u turn the sharpness up on the camera, it does it before it's compressed.
turning it up after will increase noise and somtimes macroblocks because that that point you are turning up the sharpness on a highly compressed mpeg file. so IF you know you want x amount of sharpness, I think as usual it's better to do it first and not in post
Detail: -4
VDetail: -2
Coring: -3
Colour Sat: -4
Master Ped: -7
Gamma: Cine-V
Colour: Cine
Thin
Then you have to go through and do a proper conversion to HD. I'm starting to feel like a bit of a linkwhore for posting this video every time someone asks about delivering decent HD from the DVX, but here's an example of my work with this.
http://www.youtube.com/watch?v=KALcMw-vGFw
- Vertical Detail Frequency: Thin
- Vertical Detail: 0
- Detail: -3
- Detail Coring: 0
- Skin Detail: Off
- Chroma: 0
- Phase: +3
- Gamma: Cine Gamma
- Matrix: Cine Look
- Master Pedestal: -3 to -6
- 16:9 LETTERBOX
- Shutter Speed 1/25
- 25p
Not so sure about the 1/25 Shutter. Why do you shoot at such a low shutter?
