Scene File white balance effect
Khaled Naim
when i enter my scene file manually,i cant see the effect of the color Temp. Ach exept when i take my white balance on A, and the same goes for the Bch which i can not see exept when i take my white balance in B, while the scene files which i downloaded from Panasonic to make the desired look require two settings on the Ach and Bch, when i take my white balance on preset, it doesnt take effect on either the Ach or the Bch, what should i do.
Work a bit on your English I suppose, I can't really make out what you're asking here..
Scene Files have no functional effect on White Balance. Preset WB will work for you or not, particular scene files will set certain settings of your camera, most noticable will be the CineGamma settings on your perception of colour.
Your procedure will be: 1. set scene file 2. set WB
hope this helps?
